[Engineering](/blog/tags/engineering/.md)
# From npm to a Single Binary: Adopting Bun for the Tigris CLI
Abdullah Ibrahim · February 26, 2026 ·
8 min read
[![Abdullah Ibrahim](https://avatars.githubusercontent.com/u/530615?v=4)](https://www.linkedin.com/in/abdullahibrahim/)
[Abdullah Ibrahim](https://www.linkedin.com/in/abdullahibrahim/)
Senior Software Engineer
![A terminal window showing a Bun build compiling the Tigris CLI into a single binary](/blog/assets/images/hero-image-822eba9bb78d958732b972224064e975.webp)
Recently, we released our [CLI tool](https://www.tigrisdata.com/blog/tigris-cli) to manage your Tigris buckets and objects from your terminal. When I started the project, I had to pick a language. The main candidates were Golang and TypeScript.
Golang was the strong, safe choice for a CLI, but I'm far more fluent in TypeScript. That fluency matters when your goal is to ship fast, get something in users' hands, and improve from there.
Once I'd settled on TypeScript, the next question was which runtime: Node.js, Deno, or Bun.
## Bun was always in the back of my mind[​](#bun-was-always-in-the-back-of-my-mind "Direct link to Bun was always in the back of my mind")
I'd been watching [Bun](https://bun.sh) since its early days. A faster JavaScript runtime, built-in bundler, native TypeScript support, and the ability to compile to a standalone binary — it checked a lot of boxes. But I had two reasons not to bet on it from the start.
First, even Bun's own team couldn't give a [compelling answer](https://bun.com/blog/bun-joins-anthropic#the-road-ahead) to "If I bet my work project or company's tech stack on Bun, will it still be around in five or ten years?" Node has been around for over a decade. Its ecosystem is massive. The package compatibility story is battle-tested. Bun was promising, but promises don't ship products.
Second, I wanted to stay focused. Exploring a new runtime, debugging its edge cases, working around missing APIs — that's time I wasn't spending on the actual CLI. I'd rather ship on a boring, proven stack and revisit the tooling later.
So we shipped with Node.js, distributed through npm. It worked. Users could `npm install -g @tigrisdata/cli` and start managing their Tigris resources right away.
## What changed[​](#what-changed "Direct link to What changed")
Two things happened at almost the same time.
In December 2025, [Anthropic acquired Bun](https://bun.com/blog/bun-joins-anthropic). This wasn't just a press release — Claude Code already shipped as a Bun-compiled binary to millions of developers. The acquisition signaled that Bun had crossed from "interesting experiment" to "production infrastructure powering a billion-dollar product." Bun is now everywhere in the AI tooling space, and that kind of adoption answers the ecosystem question I had earlier.
Just as we released the CLI, some users reached out asking for a version that didn't require a Node.js runtime. Some wanted to run it in minimal containers. Others just didn't want to install Node to manage their object storage. A standalone binary was the obvious answer, and Bun's `--compile` flag was the obvious way to get there.
## Getting it to work was surprisingly easy[​](#getting-it-to-work-was-surprisingly-easy "Direct link to Getting it to work was surprisingly easy")
Since we'd already shipped with npm, I didn't want to rewrite anything. I wanted to layer Bun's compilation on top of what we had. The [PR](https://github.com/tigrisdata/cli/pull/22) tells the full story, but here's the gist.
The main challenge was that our npm-distributed CLI uses dynamic imports — it reads command specs from YAML files at runtime and lazy-loads command handlers. Bun's `--compile` flag bundles everything into a single executable, so dynamic filesystem reads don't work the same way.
The solution was to create a parallel entry point for the binary build:
* **`src/cli-core.ts`** — Extracted the shared CLI logic (argument parsing, output formatting, error handling) into a module both entry points can use.
* **`src/specs-embedded.ts`** — A generated file that inlines the YAML command specs as TypeScript objects, eliminating runtime file reads.
* **`src/command-registry.ts`** — Auto-generated static imports for every command handler, replacing the dynamic `import()` calls.
* **`src/cli-binary.ts`** — The new entry point for `bun build --compile`, wiring the embedded specs and static registry together.
A code generation script (`scripts/generate-registry.ts`) reads our `specs.yaml`, walks the command tree, and produces the registry and embedded specs. The npm entry point (`src/cli.ts`) stays untouched — dynamic imports, YAML file reads, all of it. Both distribution paths share the same core logic.
With Claude Code helping me work through the static import generation and the build script, the whole thing came together in a few hours. The result: a 60 MB self-contained binary for macOS, Linux, and Windows — no Node.js required.
## Benchmarking: does it actually perform?[​](#benchmarking-does-it-actually-perform "Direct link to Benchmarking: does it actually perform?")
Performance and reliability are cornerstones of what we do at Tigris. We couldn't just ship a binary and hope for the best. Bun [claims](https://bun.sh/) significant performance improvements over Node.js, so I ran structured benchmarks to verify.
**Test setup**
* **Machine:** Apple M4 Max, 36 GB RAM, macOS 26.2
* **Node.js:** v22.14.0
* **Network:** \~350 Mbps down / \~218 Mbps up, 13 ms idle latency
* **Iterations:** 3 per test (5 for startup, 2 for batch)
* **File sizes:** 4 bytes to 2.9 GB
Both runtimes talk to the same Tigris endpoint over the same network, so the network transfer time is constant. The differences you see come from how each runtime reads files from disk, buffers data, constructs HTTP requests, and writes responses back — the runtime overhead that wraps the actual transfer.
### Startup time[​](#startup-time "Direct link to Startup time")
| Runtime    | Wall (s) | Peak RSS |
| Node.js    | 0.064    | 60.7 MB  |
| Bun Binary | 0.104    | 103.8 MB |
Node.js starts faster and uses less memory. This makes sense — the Bun binary is a 60 MB self-contained executable that needs to unpack its bundled runtime. The difference is 40 milliseconds. Nobody will notice.
### Uploads[​](#uploads "Direct link to Uploads")
This is where Bun shines. The network path is identical for both runtimes — the performance gap comes from how each one reads files off disk and pushes bytes into the HTTP request. Across every file size, the Bun binary was faster:
| File size | Node.js | Bun Binary | Improvement |
| 5.6 MB    | 1.84s   | 1.44s      | 22% faster  |
| 21 MB     | 3.64s   | 2.53s      | 30% faster  |
| 41 MB     | 4.44s   | 3.55s      | 20% faster  |
| 65 MB     | 5.22s   | 4.87s      | 7% faster   |
| 181 MB    | 22.39s  | 12.60s     | 44% faster  |
The big file result is striking: uploading a 181 MB video took 22.4 seconds with Node.js and 12.6 seconds with Bun. That's not a marginal gain.
At 2.9 GB scale, the gap held: Bun uploaded at 35.1 MB/s vs Node.js at 23.7 MB/s — **48% faster**, while using less than half the CPU time.
### Downloads[​](#downloads "Direct link to Downloads")
Downloads told a more nuanced story. Here the runtime overhead is in receiving the HTTP response and writing bytes to disk. For mid-size files (5–60 MB), Bun was dramatically faster — often 2–3x:
| 5.6 MB    | 3.73s   | 1.24s      | 3x faster   |
| 21 MB     | 7.58s   | 2.64s      | 2.9x faster |
| 61 MB     | 18.58s  | 5.20s      | 3.6x faster |
But at 181 MB, Node.js pulled ahead (45.9s vs 67.3s), and at 2.9 GB, Node.js was 16% faster while using 12x less memory. Bun's peak RSS hit 1.6 GB for the large download vs Node's 139 MB, suggesting Bun buffers aggressively in memory rather than streaming to disk.
### The verdict[​](#the-verdict "Direct link to The verdict")
Bun is faster for uploads at every file size we tested, often by a wide margin. Downloads are faster for typical file sizes (under \~100 MB) but Node.js handles very large downloads more efficiently. For our users — most of whom are uploading and downloading objects in the 1–100 MB range — the Bun binary is a clear improvement.
The tradeoff is memory: Bun consistently uses 20–40% more RSS. For a CLI tool that runs, does its job, and exits, this is acceptable.
## What I'd tell you if you're considering the same move[​](#what-id-tell-you-if-youre-considering-the-same-move "Direct link to What I'd tell you if you're considering the same move")
**Don't rewrite.** We kept our npm distribution exactly as-is and added a second entry point for the binary. The shared core means bug fixes apply to both.
**Generate, don't maintain.** The command registry and embedded specs are auto-generated from the same `specs.yaml` that drives the npm version. One source of truth, two distribution formats.
**Benchmark your actual workload.** Bun's general-purpose benchmarks are impressive, but your mileage depends on what your application actually does. We found uploads faster, downloads mixed, and startup slightly slower. Your profile will differ.
If you've been shipping a Node.js CLI and wondering whether Bun's `--compile` is worth exploring — it took us a few hours, the binary is faster for our most common operations, and our users no longer need Node.js installed. That's a good trade.
Manage your Tigris buckets from the terminal
Install the Tigris CLI — with or without Node.js — and start managing your Tigris resources in seconds.
[Get the Tigris CLI](https://www.tigrisdata.com/docs/cli/)
* [Engineering](/blog/tags/engineering/.md)
* [Build with Tigris](/blog/tags/build-with-tigris/.md)
