[Blog](/blog/.md) /
[Customers](/blog/tags/customers/.md)
# Own Your AI Context with Basic Memory
David Myriel, Katie Schilling · May 19, 2026 ·
12 min read
![Own your own AI context with Basic Memory — your knowledge, your data, anywhere your AI goes](/blog/assets/images/basic-memory-hero-e90e1ee050a9e5bb068a12b18a75132b.webp)
Quick Summary6 min read
**Per-tenant isolation.** Every Basic Memory Cloud user gets their own Tigris bucket with scoped credentials, provisioned automatically at signup.
**Markdown as objects.** Users' Markdown knowledge bases are stored directly as S3 objects on Tigris — the same plain text files they can edit by hand or feed into any model.
**Bidirectional sync.** Rclone-powered sync keeps local and cloud copies in lockstep, with Tigris's strong-consistency header ensuring fresh reads globally.
**Point-in-time restore.** Tigris bucket snapshots let users roll back their entire knowledge base to any previous state.
We are the sum of our experiences. All of your notes, your back and forth with your AI, your history: all of it shapes how AI tools help us work. There's some element of *who you are* that's contained in your context. But it's all so fragile. Switching models or changing platforms, even just opening a new chat, resets your most valuable context, and you're back to zero.
[Basic Memory](https://basicmemory.com/) fixes that start-from-zero problem. Imagine plugging a stenographer into each of your AI interactions, one that writes down everything you discuss with it, the decisions you make, the conclusions you reach, and that knows how to call up exactly the details that matter when you need to refer to them in the future. Users own and control their own context as a knowledge graph stored in plain Markdown files, no proprietary formats. You can edit your notes directly via an Apple Notes-esque webapp or you can use their MCP server directly in your AI tool of choice.
When building their cloud offering, Basic Memory needed a storage backend that could support their vision technically: strict isolation between tenants, instant provisioning, and sync that didn't bankrupt the platform. Tigris checked all these boxes. The bigger thing was that Basic Memory and Tigris believe the same thing: **you should own your own data, and bring it with you, without restrictions.**
## Knowledge that belongs to you[​](#knowledge-that-belongs-to-you "Direct link to Knowledge that belongs to you")
Basic Memory started as a Thanksgiving-weekend project in 2024. Paul Hernandez had spent twenty years writing software for startups and large companies, and he used Claude and ChatGPT daily. Built-in AI memory was in its earliest infancy. Chat couldn't possibly save all the information he wanted it to, and Claude didn't even have a memory at the time. Paul could foresee issues with inevitable product lock-in once they did. How could he save all the context he wanted? And how could he switch to a better model without paying the exit tax? When Anthropic released the [Model Context Protocol](https://modelcontextprotocol.io/), the path was obvious: give every AI assistant access to the same knowledge base through a single MCP server, stored as plain Markdown.
Conversations with any AI produce structured Markdown containing observations, tags, and wiki-style links between topics. A local SQLite database indexes everything for full-text search. The MCP server exposes the knowledge base to Claude, ChatGPT, Gemini, Cursor, VS Code, and any other MCP-compatible tool. Both the human and the AI read and write the same files.
Basic Memory's edge over built-in AI memory features is partly the sheer volume of information it can retain, link together, and call up on command. But, philosophically, their edge (and virtually their one-word motto) is transparency. Basic Memory's is a folder of Markdown files you can open in any text editor. With more than 3,000 GitHub stars and 57,000 downloads per month, it has found its audience among developers and knowledge workers who want to own their AI context.
Your knowledge should be yours. AI does what AI does well, but ownership stays with the human. Switch models tomorrow, and your knowledge comes with you.
Paul HernandezFounder, Basic Memory
![Paul Hernandez](https://avatars.githubusercontent.com/u/60959?v=4)
## One bucket per brain[​](#one-bucket-per-brain "Direct link to One bucket per brain")
The local-first version keeps everything on the user's machine, which is how users in high-security environments build shared knowledge bases on the open-source release. In October 2025, the team launched [Basic Memory Cloud](https://basicmemory.com/cloud), a hosted knowledge base available across devices, browsers, and AI platforms. The cloud product needed multi-tenant storage with strict isolation: each user's Markdown files, organized by project, in a bucket no other user can reach.
Their first build-out was a direct port of the local one. Each tenant got a dedicated Fly.io server, with their SQLite database and Markdown files on a per-tenant Fly volume. It worked on day one. It didn't scale. As Paul put it: "a single server in the cloud, you're just asking for problems." Running N instances and volumes per user for redundancy spiked the cost.
So they moved the isolation: same servers, different buckets. A small pool of multi-tenant servers now sits behind a gateway proxy that handles authentication and routing. Each tenant still gets complete data isolation through their own Tigris bucket, their own Neon Postgres database, and scoped credentials that can only reach their data. **Storage is strictly per-tenant; compute is shared.** The platform runs on a handful of servers instead of N, and per-user cost stops scaling linearly with users.
Everything is a distributed file system — a giant key-value store in the cloud. By keeping Markdown files in S3-compatible object storage and indexing them into Postgres, we get a system that's simple, scalable, and extremely cost efficient.
That architecture only works if per-tenant bucket creation is cheap, fast, and programmatic. The [Tigris Partner Integration API](https://www.tigrisdata.com/docs/partners/) does that. A user signs up, [Polar](https://polar.sh) fires a webhook to Basic Memory, and within 5 to 20 seconds the tenant is fully provisioned: Tigris bucket, Neon Postgres database, scoped credentials, and all internal configuration. Users see a brief spinner on a welcome screen, and the platform is ready.
Each tenant gets their own bucket with credentials that can only reach that tenant's data. Projects within a knowledge base are organized as prefixes inside the bucket. There is no shared "tenants" bucket, no row-level security to get wrong, no custom isolation layer to maintain.
At runtime, the gateway proxy resolves the tenant from the request, attaches the right credentials and database URL as headers, and the shared API pool reads and writes against that tenant's bucket and Postgres only. The rclone sync path skips the API entirely and talks straight to the tenant's bucket with its own scoped credentials.
FIG 01shared compute, per-tenant storage — the bucket is the isolation boundary
  client layer
  │ web editor │   │ MCP clients               │              │ rclone bisync │
  └─────┬──────┘   │ (Claude, Cursor, VS Code) │              └───────┬───────┘
  shared compute                                                      │
  │ gateway proxy           │                                         │ direct S3,
  │ auth + tenant lookup    │                                         │ skips the API,
  └─────────┬───────────────┘                                         │ tenant-scoped
            │  X-BM-Tenant-ID                                         │ credentials
            │  X-BM-Database-URL                                      │
            │  X-BM-Bucket-Name                                       │
  │ cloud API pool          │                                         │
  │ (multi-tenant)          │                                         │
  │ tenant A, isolated │  │ tenant B, isolated │  │ tenant C, isolated │
  │ Tigris bucket A    │  │ Tigris bucket B    │  │ Tigris bucket C    │
  │ scoped credentials │  │ scoped credentials │  │ scoped credentials │
  │ Neon Postgres A    │  │ Neon Postgres B    │  │ Neon Postgres C    │
## Sync that pays for itself[​](#sync-that-pays-for-itself "Direct link to Sync that pays for itself")
Users own their files. That's a core design principle, and the cloud product extends it: edit locally in Obsidian or VS Code and sync to the cloud, or edit entirely in the cloud via the web editor and sync back down. Any amount of data can flow either direction. On a traditional cloud that's a cost problem; on Tigris, Basic Memory ignores how much data leaves their platform.
The sync engine is `rclone bisync`, pointed at Tigris's S3-compatible endpoint. Each sync fetches the tenant's scoped credentials from the cloud API, then runs a bidirectional sync between the local project directory and the corresponding path in the tenant's Tigris bucket. Markdown files are stored as-is — the same files you'd edit locally are the same objects sitting in S3.
Tigris is globally distributed by default. A user in Singapore writing from Cursor hits a nearby Tigris region instead of round-tripping to a single origin. That latency math is what makes "sync everywhere" feel instant rather than tolerable. The cloud product would be a noticeably worse product if reads always came from one region.
Global distribution comes with one tradeoff: edge caches can return slightly stale data for reads far from the origin. Basic Memory handles this by sending the `X-Tigris-Consistent: true` header on every rclone operation, forcing strongly consistent reads and preventing subtle sync issues. The header is applied globally rather than per-method because bisync starts with an S3 `ListObjectsV2` call, which isn't a download or an upload — list-only headers would miss it. It's a small detail, but it's the kind of thing that turns "works in demo" into "works in production."
For new objects landing in a tenant's bucket from any path — the rclone sync, the web editor, or the API — [Tigris bucket event notifications](https://www.tigrisdata.com/docs/buckets/object-notifications/) tell the cloud API which files changed, so the indexer re-reads only what it needs. No polling, no scheduled scans.
FIG 02how an edit flows through Basic Memory — every path converges at the index
  │ local machine │ ◀─────────────────▶ │ Tigris bucket │ ────────────▶ │ cloud API      │
  └───────────────┘    rclone bisync,   │ per-tenant    │  bucket-event │ Postgres index │
                    X-Tigris-Consistent └───────────────┘    webhook    └─────┬──────────┘
                                            │ web editor │         │ remote MCP clients │
Egress is the load-bearing economic detail. Users sync files back and forth all day, and agents re-read the same notes while building context. That bill compounds fast. Zero egress is how a four-person team can offer sync to every customer at a price they'll pay.
Without zero egress, sync per user is a margin killer. With Tigris, it's the mandate that makes the platform work.
## File-level history, for free[​](#file-level-history-for-free "Direct link to File-level history, for free")
Basic Memory uses [Tigris bucket snapshots](https://www.tigrisdata.com/docs/buckets/snapshots-and-forks/) so users can recover to a point-in-time, whether or not they manually take a snapshot. But the cool part is how Basic Memory used bucket snapshots to build a more granular feature: file-level diff/merge.
Because every change to the bucket is persisted with a snapshot ID — similar to a version SHA — Basic Memory can fetch every version of a Markdown file and load the changes side-by-side in a CodeMirror MergeView. A `ListObjectVersions` call returns every version of a single Markdown file, making it easy to inspect and compare revisions. The user picks which changes to keep, much like resolving a merge conflict in Git.
As Paul describes, "I had experimented with integrating Git for this and it was such a chore. This pairs really nicely with our bucket-level snapshot feature — a user can use snapshots to manage versions for large numbers of files, or use the file history for a single file."
Download the [MP4 ](/blog/img/blog/case-study-basic-memory/basic-memory-file-versions.mp4)version.
## What Tigris solved that other clouds didn't[​](#what-tigris-solved-that-other-clouds-didnt "Direct link to What Tigris solved that other clouds didn't")
Paul previously worked at the biggest AWS customer in Austin, so he knew what $bigCloud infrastructure costs in commitment — the kind of complexity that comes from being too big to question. He dealt with account vending machines for new tenants, continual quota-increase requests as the user base grew, and the exit tax of egress fees if you ever wanted to run compute on another provider.
I wanted to build on a modern stack that lets us do right by our users — not lock them in or charge them more than we have to. What I appreciate about working with Tigris is that they approach it the same way. They're not trying to squeeze us on pricing, and having a provider that thinks like that means we can pass those savings and that trust directly down to our users.
Tigris is the good parts of AWS without the bad parts.
He wanted to build differently. Tigris fit. Per-tenant buckets, zero egress, globally distributed reads, bucket-event webhooks, snapshots: each one already existed as a primitive, not a feature request. The architecture didn't have to bend around the storage layer.
## What's next[​](#whats-next "Direct link to What's next")
Basic Memory recently shipped an updated web editor, improved semantic search, conversation import from ChatGPT and Claude, and per-project cloud routing — individual projects can route through the cloud while others stay local. Coming soon is a **teams product**: organizations where each user keeps their own bucket but shares an organization-level bucket for common knowledge. New team members can fork the shared bucket and start with a base set of notes instantly.
Regional bucket placement is on the roadmap too. One open-source user is the CISO of an EU bank using Basic Memory to manage bank infrastructure processes, and EU data sovereignty rules dictate exactly where bytes can live. With Tigris, putting a tenant's bucket in a specific region is a configuration choice, not a project.
For a four-person team, the less time spent on storage infrastructure, the better. Tigris handles tenant isolation, sync, snapshots, and global distribution. Basic Memory spends that runway building something most AI products refuse to: a memory layer the user actually owns.
Build a multi-tenant product on Tigris
The Partner Integration API gives every one of your users their own isolated bucket with scoped credentials in seconds — no custom isolation layer to maintain.
[Read the Partner API Docs](https://www.tigrisdata.com/docs/partners/)
* [Customers](/blog/tags/customers/.md)
* [AI](/blog/tags/ai/.md)
* [MCP](/blog/tags/mcp/.md)
* [Multi-tenant](/blog/tags/multi-tenant/.md)
* [Object Storage](/blog/tags/object-storage/.md)
